how thick are you leaving it?
this one is only a tiddler (4 1/2") so perhaps that helped. it was a core from a larger bowl that i bough inside the house to see how much weight it lost so i could judge when the rest were dry. i left it next to the fire to force dry it, there was no pith so i was happy that it would be ok.
i've had good experiences with all the cherry species...
I tend to go fairly thin on most bowl projects and I'm leaving approx 1/2" of 'meat' on before leaving it in shavings and eventually finishing it off.
Should I be leaving more on during the initial rough out and drying?
it varies with the wood a bit, i'll leave 1/2" on little ones and go up to 1" for something 12" across and up to 1 1/2" at 18"
Ok thanks, I'll be leaving a bit more wood for bigger bowls in future.
I " rough out" all of my bowls , but do virtually all of them in winter so they slowly acclimatise to moisture loss , and put them in a well vented shed , it depends on species how much I leave oversize and if I intend to make a thick or thin walled bowl . Any wood I acquire in the summer I usually wrap in cling film until the winter arrives , but I still lose some now and then ! Sometimes I coat end grain with PVA
with the fruit woods and others prone to splitting i will always seal the endgrain once roughed out as this will give you the best chance of having a good yield of bowls once dry...
Ah.....right. I haven't been doing that.
Thanks for the tip!
