  Matthew Storrs said:
Anything is possible with a digger- you just need to be creative:laugh1:
I like ya thinkin'
Thanks for your thoughts, really helpful.
Is it the geometry that makes the towing tricky?
Any more stories of small diggers in woodland management greatly appreciated.
If your towing a fairly heavy trailer and try to turn gradually by applying more pressure to one track than the other, I found the dominant track tended to spin out a bit. Don't get me wrong, they are more than capable of towing a decent load behind but don't expect it to be quite as smooth and flowing as it would be behind a tractor. A single axle trailer would be considerably better than a double axle mind you.
Another improvement on the trailer towing thing would be to devise some sort of ring and pin hitch with a self supporting leg/jack on the draw bar of the trailer- purely laziness but I'd quite like to be able to hitch and unhitch without having to get out of the cab and faff around with a jockey wheel.
3 tonner will easily lift half a ton of logs- I picked up a full dumpy bag 850kg of gravel with mine today and it didn't seem to struggle.
Reference towing a trailer- on the back of this thread I bolted a tow ball to the dozer blade last week. I have been towing an I for flatbed with a bundle of fencing stakes accross fields no problem, turning whilst towing isn't great so its best to travel in a series of straight lines, turn on the spot then head off on the new line.
I have this idea of towing an I for 8x5 tipper which I could load with soil/stones/timber and then use the auxiliary hydraulics on the digger arm to tip it. Needs a bit of thinking over but could be a handy setup for some jobs.
If you want to tow your 8x5 Ifor tipper which I assume has no electric tip, then simply tap into the blade supply to have full control over tipping from the comfort of your seat.
I fully agree on how the trailer will hinder turning, with perhaps a single axle trailer on larger diameter floaty tyres being ideal, but again something else to get to site.
Eddie.
Eddie.
Yes that's a great idea tapping into the blade supply to tip, would save connecting a hose to the dipper every time I want to tip:laugh1:
The trouble with all these projects is how practical they really end up being, I'm sure a tipping trailer behind a digger would be fantastic for certain odd jobs, but I can't think it could ever stack up against just having a dumper on site if there was much to be done.
  • 1 month later...
Read more
