The leg definitely makes a difference from the 1 I've used which didn't have 1 to help over stumps and pulling stuff about, realy tidy job you leave 👍top job.
It's surprising how much I use the walking leg to move dead and windblown stuff around, and by simply stabbing it with one of the teeth you can actually lift material around quite easily.
It's transformed the job, and results much less damage to surrounding trees, as material is dragged away from them and then mulched.
Very kind comments thanks, I'm only as good as my last job, and taught old school, always leave a job happy to pay for it yourself!
Eddie.
Didn't realise you pulled out rhodie stumps as well, and mulched. A great service when you compare to conventional slash, burn, break your back with a chainsaw techniques, yes indeed.
It most feel great standing back at the end of a day and seeing the clean up progress and the return of defined parkland.
It looks a bit hillbilly made and I like it, telescopic dipper, grapple saw, hydraulic rising cab, winch in the trackframe and a bit of extra counterweight all in a compact size
Just a few of a Rhodie job that simply couldn't be burnt or mulched by excavator due to a road in close proximity.
We used a long reach and grab to stack the material on the track, and then put a Tractor and mulcher through it.
Having raked the sides in again, the mulcher did a final pass, leaving the material ready to be removed and the track exposed again.
I'm just finishing off clearing the road with 13tonner and Tilt bucket, but I'm delighted with the results.
Eddie.
