I'm getting a MS461 and would also like to do some milling with it but what size mill should i get and what is the largest size timber i could mill with that saw?
A461 will run nicely on a 25" bar and chain, then from reading the milling threads i think you have to minus 6" from the bar length due to fitting the mill so you'd be looking at 19" bud
I went for a slightly bigger mill as you can adjust it to fit your saw, the 30" Alaskan and a mini mill make a good combo, I originally only had a 576xp with a 24" bar but now have a Makita 9010 with a 30" so I went for the 36" Alaskan mill. Hope this helps buddy, feel free to pm me or 'rob d' is the bloke to talk to
Sent using Arbtalk Mobile App
And 19" inch is still a decent board, if you bought the mini mill to take the sides of you can mill bigger diameter wood to get it to 19 wide :)
Would think a 30" Alaskan would do, you can alway purchase the bigger rails if you do get a bigger saw :)
Millings much tougher on he saw than cross cutting. If you've just got a 46 and have no real plans to get a 100cc plus saw maybe consider the mini mill, cheaper, smaller to store, still do 18" and prob what a 46 would be happy milling
I was going to mill 16-18" with the 46 a few weeks back but bottled it and used the 88 instead
my 576xp pulls the mill well (same size as a 460) for milling smaller peices, i think a combo of a mini mill and a 30" alaskan would be ideal,
The mini-mill is very useful, but for milling reasonably accurate thickness boards/slabs you really need the Alaskan.
With that saw, I would buy a 36" mill (because inevitably you will either enjoy milling and buy a bigger powerhead or not like it and sell it on, in which case the 36" is more versatile). As mentioned, you lose quite a lot of bar length - about 7-8" if you leave the dogs on. This means you can afford to put an over-length bar on, something around 28" or 30", which would give you a cutting width of around 22" and the saw will handle this reasonably well.
If you want to run a bar which is on the long side, Granberg chain is reckoned to demand a bit less power (~10%) although it's more expensive. You also need a precision grinder to keep the teeth absolutely identical to put less demand on the powerhead.
Alec
