as it says in the title, oppo and I have just spent 3 days selectivly thinning a small plantation of larch and sitka of around 25-30 year old trees,(never been done before), and apart from 3 or 4 , every one has hung up and had to be winched down, most of them with a manual winch as its to tight to get even the mini tractor in, and we've got another week of this, I had almost forgotten how much I hate thinning:thumbdown:
Hideous, it's so exhausting. Sometimes we just use a 4:1 pulley system instead of a winch as it's easier to move around and weighs very little and is quick. Trick is to anchor it off a tree at about head height and it helps lift the butt instead of ploughing the forest floor.
Good luck with that, rather you than me.
have been using a lightweight 4 ton winch, the tajfun on the tractor and a rope with 2 pulleys, even at that my shoulders are goosed, there just isnt an easy way that covers all the problems....oh for some open spaces....lol
We've got a petrol powered capstan winch which is easy to carry and anchor to a tree then choker the butts and winch with little effort. Great piece of kit, you can get a nose cone which stops the butts digging in the ground to. On a job like yours be well worth a look.
Sent using Arbtalk Mobile App
If you just need to get them down, without preserving limber value, you might try this cut.
[ame=http://www.youtube.com/watch?v=eUQ1p2QPdxU]widowmaker trip.mov - YouTube[/ame]
Doh!
I taught dat was a dumb bodge:001_rolleyes: of farmers son cut.
So I can actually call mesel an "advanced" sawer/feller:001_tt2:
Wow
better give mesel a payrise for that.:lol:
I like a lot of your techniques Dadio and I liked the demonstration you gave several months ago to get a hung up tree down (which you got a lot of flak for). I am not so sure about this one though! Maybe I will watch it again.
I'd like to see him try that in a sitka plantation....the tree drops 4 feet and stays hung up...why do all these guys demonstrate on big open areas, they need a go where the trees are all about 3 feet apart....and covered in short spiky branches whos one aim in life is to jag you......not cost effective to bring in a harvester, so joe blogs and co. get to do it
