  • Replies 33
Does a 16mm pulley only allow the use of a 16mm split tail/loopie etc?
Good question.
I would have thought whatever you can get in there is fine but I don't know.
Big chunky split tales hold a knot really well and don't seem to slip on the tree when snatching that's why I like them.
With our big split tale you have to hammer the eye flat to close the pulley back up.
Good question.
a crushed splice or a reduce bending ratio would surley cut the strength of the split tail severley? yes?
Knots would exagerate this as they cut the breaking strain massivle (40%ish?)
Good question.
do you not think that maybe thats not a suitable split tail
i am not sure what your doing but be carefull
I understand what you are saying, but it doesn't feel or look wrong to me. I think the bend ratio is fine in the pully/split tale combo and the rope is very soft so doesn't really get crushed to much. A lot of the problem with closing the swing cheek is caused by the protective sheath on the splice.
Cheers for the heads up Pete I will defiantly give it a bit more assessment when I put it together next.
thats a 24mm then i think which i would guess is not what your pulley should take the blue 19mm is good and goes with the 16mm lowering rope
very hard to do from descriptions
Cheers Bob we have a blue 19mm. The green really only comes out when the blue is to short to get enough tucks on the timber hitch.
Do you think there is a potential problem with using the larger Split tale with the pulley ?
