Brambles/Lawyers
chris hennelly
Good Morning All...Is there a better way to clear Brambles than Chainsaw?
100m long,2m wide,2m tall,stems thicker than thumb base,against 1.8m brick wall........................................pedestrian access only! I have a BCS Tracmaster,so would maybe consider an attachment?
Brambles not on Clients' ground so extreme solutions!?! not permitted.
the big stems at bottom cut them out and use later for walking sticks as other post blade on strimmer and go down from top not into side of them will chop them all up into bits. do that lot in a couple of hours.
It's a lot easier if you have someone with a rake pulling them away from you as you go in with the brush cutter. Saves you from getting all tangled up in the thorns.
I cut self set acacia trees in the same way. You really don't want to get caught up in those blighters.
