no primary relief for each spool just a main relief most blocks dont have a relief that is on the cyl side only on the feed to the spool via load sensing once its thru the spool its locked in by load hold valve in the spool
  • Replies 31
That's impressive. If you can build another for similar money then you'd make a killing. The nearest machine to that s the tracked predator. Well done
But if he made the commercially he would have to charge for all the hours of labour, profit margin etc, doubt he would make a killing then:(
That was not aimed at Rob, just a thought.
From my experiences he would sadly find that in general a lot of people who say "I would buy one" don't put thier money where thier mouth is when it comes to the crunch.
Something very satisfying about building kit like this yourself and actually getting it out there working for the first time, even more satisfying if it works exactly as planned first time, but most need some tweaking.
i prefer doing one offs with whats lying to hand it was a project that used up quite a lot of materials and a lot of machining hours
Did the 2grand include all your time though?
