Had 1 for 6 years great hedge cutter/trimmer cuts everything, had a couple of problems to start with it spark arester would block up just removed it then the air cleaner would suck small cutting when trimming conifer and block it up piece of tape over the holes on front case solved that. The biggest problem with them is they scream like hell the loudest hedge cutter I have used but the balance is right with engine to rear used it all week and going to use it next week as well.
I do not own a standard format hedge cutter/trimmer.
Watch the starter mechanism, lad I do some work with had 5 with broken starters the other week. Dealer put new parts in one of them 1 start and starter wrecked again. Mind you he uses them hard with little maintainance, they do not like drop starting. Mind you keeps the dealer busy
Must be the new ones as no trouble with mine only replaced start cord last week after 6 years.
