I have been asked to make up a house sign for neighbor. I have had a practice in the workshop first carving with chisels then using a router. Can't say I am happy with what I did either way. Carving was very slow so going to be expensive and routing left marks that needed cleaning out with a chisel afterwards. My customer want's it unpainted so what would be the best way to go about it?
Another problem was simply drawing the lettering I have printed off onto the wood. I could just draw freehand but it needs to look crisp and neat and my drawing is not up to that.
Any help welcome
Alternatively give me quote :thumbup:
  • Replies 29
Send off the design to pensofdistinction and he'll laser engrave it 👍
Have you seen the thread 'wooden business cards' quite a few including myself have them are they really are spot on
For the lettering I print it off and copy it on with carbon copy paper, using a ruler or free hand.
What marks are left ??, is it a round like burn mark or slightly different levels.
Ye hoped you would come to the rescue.
With the first cutter it was burn marks (presume it needs a sharpen) with the second it was as you say slightly different levels as the cutter is a fair bit narrower than the intended lettering.
Burn marks usually means, blunt or going to slow. As for the levels I find that sometimes it's just that your not adding the right pressure when your going for the second pass. I always use a smaller cutter anyway I find it easier, I also use a chisel to to get rid of burrs and then a light sand.
I was using a bullnose cutter. Do you do most of yours with a straight cutter?
Yes I would say 90% of it with a straight cutter 1.5mm to 3.5mm trend cutters.
Read more
