  • Replies 46
ok that makes sense.thanks.
...Does the fuel economy get worse?:blushing::blushing::001_cool:
It uses the fuel you have more efficiently and it cuts faster so you get more work done in a shorter time soooo I would say no , not worse but different ! if you see what I mean
ok....yep i see....does it pay to put 95octane fuel in or is it no different.im currently doing 15l of mix a day and want to reduce the cost and up the cutting.
I think you would up the cutting but use the same or slightly more fuel but in proportion to the timber on the deck at the end of the day it would be more economical
What diameter are the pine?
there is a mid size plantation in the middle of an area im working.just small ish stuff but i have to move quick.need to fell and stack 50 a day to get it out the way and my husky 362 is dead zed....:laugh1:
well ill get the saw stripped down and get the dremmel out then.....
can you get a stroke kit to increase cc too?
any info on the work to do?:biggrin:
