Let me know of the serial number and I'll check the provenance if you are at all unsure. If you feel you need to talk, call me on 07774 282481. Cheers.
Run greenmech for a good few years now good well made machines with good factory support, easily better than a tw.
The only thing you need to watch is the reps :D
We have two of them. I think they're really good chippers, can't think of any problems we've had in the last four years that weren't our own fault. Throttle cable sometimes goes but apart from that, top notch. Circular blades too, so you can get a bit longer out of them before you need to have them sharpened.
Absolutely brilliant machine, had mine over 3 years with no problems.
I would personally never go back to TW.
Can't speak for other makes.
Our local hire centre bought one about 18 months ago and we take it out pretty regularily. It's a cracking wee machine and does all asked of it. The only problem we ever encountered with it was an overheating issue during the really hot spell in July when the radiator screen clogged up wiith dry material causing things to cook up a bit. Problem easily solved by checking and clearing the screen more regularily in those hot dry conditions (which we probably should have been doing anyway but we're just not used to more than 2 hot dry days back to back in NW Ireland!)
Best of luck with the eco-arborist. Don't think you'll be disappointed
