  • Replies 98
Yes
I've used one a fair bit,we attached to Trees with a "Ratchet tie down".We had to often notch the bark to get either the device or Ratchet strap to sit propperly.
I don't rate it as high as a "Porta Wrap" as its not as fast/easy to set up.
Really requires two people to attach it to larger Trees
I use one like that but it already has the strap and ratchet attached to it, its from fujikura and about £350 i think. I think its well worth it but it is a struggle to put on by yourself.
does it have a metal handle to tighten it on the strap? if that took a wack from a log it could break. i think i would prefer a sling.
