Evening
Strange one
My ms261 keeps cutting out
I stripped it down including the clutch
Masses of dirt under clutch drum plate
Gave it a good clean and went to re assemble but can't seem to get the clutch drum back on properly
The re alignment line that then sits down is not interested
Such a simple thing to do on the older models
Any ideas
Many thanks
Sent using Arbtalk Mobile App
  • Replies 50
Ok. Is the line or notch in the drum lining up with the oil pump drive gear arm? Should be able to see it? Its behind the clutch. Can run a piece of stiff wire around the clutch and it should push the arm round so you can line them up?
Can't see the drive fear arm
Will gave a look in ze morn
But how would that explain the cutting out when the chain brake is applied
easy Rich !
T:lol::lol::lol:
It wouldn't but it would explain why the drum not going on.
The cutting out could be many things. Like carb issue.
The impulse line do have a tendency to go on these.
Is the carb adjusted to factory, and does it make a difference if adjusted. Also what is the plug colour?
I have a great fix for a ms261 problem, it's called the husqvarna 550xp, available from any good dealer
