Fuel filter? Its the lil plastic clear tube connected either end with black pipes. Are tracked chipper wouldn't start, checked it and was full of cr@p so swapped it out and runs fine now
  • Replies 20
Did the starter turn?
On newer chippers they have 3 lights on the engine management and before starting (2 re and 1 green)the green light shows.
With ours 2005 we have 4 lights (3 red and 1 green)and none shine when turning to 2
We're now thinking engine management board and will check with a newer one this weekend. BTW- injector solenoid OK
When the filter blocks, you get a turning starter and sometimes then a few minutes of chipping which gradually ends up being none.
The starter still will turn I seem to remember.
This is a situation where we hear no starter action just fuel filter on 1. After 1 there is no sound or light.
Hi,
The symptoms you describe may well be associated with a discharged battery, faulty starter motor or a bad contact between battery/ignition/starter motor.
Timberwolf Technical support may be able to offer additional information if needed.
Timberwolf technical can be contacted on 01449-765820, please have your model and serial number to hand.:thumbup1:
Thanks
Will call tomorrow
