Had a bit of timber left over from another job so put this togther yesterday. The bolsters may need beefing up a little but time will tell! Hopefully I'll get at least one season out of it
:001_smile:
Thanks seems to be strong enough so far, put about 10 cube through and no wobbles yet. Definitely much quicker, ive been putting the thin sticks in and billeting the bigger stuff with the X27
Looks good, holds a fair bit. You clearly process more wood than I do! Maybe I should start cutting my logs more than one at a time! :)
It works for me on the little diameter stuff .......:001_smile:
Looks really good! Only nag with it is its a pain to pick them all up off the floor after with so few slats to hold them in. Unless you cut them into longer lengths. I have one and cut to around 8 inches
