I want one in mine John, it has been done, won't be cheap, I read of someone who does the conversion with a brand new engine and box but its 30k
Sent from Outerspace.
HI HODGE i can get the engine of CWS in glastonbury somerset they will have loads i no chaps who can do the job a lot less then that thanks jon :thumbup:
  • Replies 62
I have just been looking on a landy forum and if I get an engine then a plug and play ECU and wiring harness is under 3k. So I would need to get an engine and box. It would be awesome.
HI HODGE there one of the largest 4X4 breakers in the uk mate CWS they will have loads of them thanks but like you say you need the lot and some one who nos what there doing thanks jon :thumbup:
Thanks Jon, I will look into it, its not something I am gonna rush into but I really fancy it.
Regardless of power, what will 5 cu mtrs of chips to to the GVW?
That could be a 1.7 ton payload - what is the net weight (with kit, driver etc) of a 130?
HI HODGE i will ask my mates as his dad done the 6 wheel drive conversion mate he was the 1st to do it so i no the chaps down here to do it thanks jon :thumbup:
The TD5 will be fine standard, my mewp & trailer combo goes at 2.6t, & its a breeze to tow.
I did get mine chipped, but that's because I wanted to, not needed to.
I am told the payload could be 1200 ish but I don't know for sure. So yes you have a point. A full 5cube might be a bit too much. But I was just trying to give a comparison for others to have some idea.
