I quite like them, and have used for many years as a decent side strop or adjustable lanyard for work positioning. Personal preference I suppose
What length is the lanyard, could replace with longer if you wanted, 2,3,4 or 5 metres.
Cheers
They are a lanyard adjuster, usually supplied with the lanyard of varying lengths, so not much else you can do with really, other than use it a lanyard!
you can make up a different length, but iirc they work best on 11mm rope. 13 will work but not as smooth. I found mine great while the rope was clean and not gunked up, but once it got a bit of muck on it it struggled to run with ease. In the end I sold mine and changed to a hitch/micro pulley. also I found you couldn't use it with the grillon on the left side of your saddle.
I have one in my kit bag,it's only a 2 metre length and I get it out from time to time. If it's a small tree and I don't want the hassle of dragging my life line and a tail of lanyard through crotches. To be honest I only have one because someone made me an offer I couldn't refuse so I bought it. Other wise I can easily do without it. V.t and pulley works far better IMO.
Jake:thumbup1:
