amenity weedkiller
miker
We're using Rosate at the moment. Seems to work well enough like other similar strength gly products Clinic ace is the same strength 360g/l
Some "stick" better than others but the active ingredient has the same kick.
If you want to move into the stronger formulation you need something like Roundup Energy, Pro biactive 450 or Gallup Hi-aktiv. Check field of use restrictions first.
I,ve yet to use a formulation of glyphosate that doesn't work, some just take longer to act.
