SRT base anchors and rescue anchors
  • 1 month later...
I would strongly recommend a figure of 8 with ears in this application.. As we all know base anchors end up going slack at some point during the climb. In which case the figure of 8 can end up with a girth hitch.. either that or just pop a bight through a normal figure of 8 and clip the bight into the biner... safety first kids.. theres no point in having a lowerable system that gets stuck
I'm sure you're making a good point Ben but I can't imagine how the girth hitch could happen.
I'll try and make it happen tomorrow if I remember.
Is anyone using descenders like and Id or Rig for base anchors? Theoretically should be good no? Hard lock it through karabiner That way no knots to contend with; lower climber/casualty to ground straight forward
Some people do use them but I don't because I don't have one and they're so expensive.
Rig good. ID bad. Panic feature gets a bit funky and engages all the time due to the friction over the branch/es
