On ‎18‎/‎03‎/‎2018 at 11:46, daltontrees said:
Nasty situation found inside bulging overextended Poplar limb at an upcurving point. Is this Poplar's answer to hazard beam failure?  I plan to make a clock face out of it, if it doesn't fall apart during drying.
Internal torsional twisting damage which happened in very high winds?
Tim/David, I have no pics of the branch, it just looked like a standard limb removal as I was groundie for the day, and I didn't see the cracks till it was mostly in teh chipper and the heavier wood was getting ringed up. It was a fairly hefty old Poplar that had been topped severely about 15 years before, and a lower branch had gone mad, it started horizontal and stretched out for about 15 metres, curving progressively to the vertical. The section I have is about 35cm diameter, but it was in a bulge and the rest of the limb was only about 30cm diameter before and after the bulge. The bulge was in the classic hazard beam failure position, on a section about 20 degrees off hrizontal.
I've always assumed beam failures are instigated by torsion due to end wind loading, rather than by dead loads.
  • 1 month later...
Hi guys just wandered what might of caused these growths I was thinking the second two pictures could be cross sectional flattening or fibre buckling except the tree had a small canopy so not sure. The first oak had patches of bark losses could this be due to bark necrosis due to the lean of the stem?
Cheers again.IMG_20180425_093330.jpgIMG_20180425_092335.jpgIMG_20180425_092329.jpg
2 hours ago, Will Ingleton said:
Interesting Oak in Trent Park. Enjoying that the weather's nice enough to take the time to have a good poke around looking for this sort of thing emoji1.png 20180506_112219.jpg
Fine inosculation.
some really great trees across Trent Park
