Flames
Forest2Furniture
Thats the special built in cigarette lighting feature, an optional extra on the MS880 - it must be the delux version - I believe this can be retro fitted but only on a face to face basis:001_rolleyes::lol:
Seriously - I think Rich is probably correct, you must have unburnt fuel build up in the exhaust which is igniting and causing the flames. It may be your machine is running a little rich but leaving the saw ideling for a while after use will let the saw clear the unburnt fuel vapour.
Worth checking the plug colour after a good run - if the central electrode is coffee colour all is well!
when Im milling, especially on long runs, when I get to the end of the cant, I let the saw sit on idle for around a minute, then a couple of blips before I switch it off, Ive found this is the best option to guarentee a first or second pull start on the next run, dont be scared to stop, sit the saw down , and fill the cup at any time, gives the saw time to cool down and makes the job more enjoyable as well
