Crane Felling Vid from Ground view/Training
MOG
Hello
this is a Video from job the other day. i was just brought in for well messing round on ground. usually i climb but newer guy wanted to do it. this great Vid for learning and what happen and what the problems where. I let you put your own thoughts down and i will answer with mine, hope you learn something and enjoy it.
whole tree was finished by 2pm, some scary bits a end
thanks MOG
  • Replies 27
Great video! Weather looked perfect , one thing I noticed on the last chog he tied into the crane hook surely on a heavy lump like that its a bit dangerous? Only done one crane job myself so I can judge but I did like the idea.
Sent using Arbtalk Mobile App
Hi joe, I noticed that but didn't like to say:thumbup1:
Naaah that's OK, it was a well executed job and that manoeuvre was clearly planned, the crane driver knew what was going on and did his job well. A cambium saver in the hook would have reduced the (remote) chance of the rope nipping as the chains came under load but other than that I cant fault it.:thumbup1:
I guess if the crane driver knows to keep the weight on the stump then your ok but some crane drivers who are not so experienced could load that side ways taking you with it, iv seen some shocking crane drivers I wouldn't dare do that with one we have used but like you say it did seem controlled.that is one tip noted.
Like you say, you would need to know and trust the driver
