Tree House
Jaarkeal
I want to build a tree house for my children in this Oak tree. I have never done such before and was just interested in peoples advice and opinions.
Has anybody built one ? I want it to last so I was thinking bolts into the tree would initially cause the most damage but may heal and be a better long term option ?
I could put it on stilts but would it look as nice and how much damage would concrete pads do to roots ?
Eventually I would like to have a zip line from it and a bridge to it from a nearby Sycamore. All plans in my head at the moment though.
Any feedback would be much appreciated.
If you use nails or bolts made of steel the oak will eat them, so make sure they're galvanised or plated and just put the posts straight into the soil as it will take a few years to rot, in that time you could attach a set of legs to each post, for the zip line use something similar to a cambium saver so you don't choke the part of the tree it's attached to
Sent using Arbtalk Mobile App
I put up a stilt house about ten years ago and its still as sturdy as it ever was.
As mentioned insert 5-6m long treated round posts 100mm diam straight into the soil and about 0.7-1.0m deep. Pack well.
Brace the 4 posts using 100x50mm treated spars at the height of the platform. Fix with coachbolts to create a sturdy structure which will then allow you to fix a platform to.
After choosing a suitable location for the platform, use two pieces of treated marine grade plyboard or wood planking. Cut a circular hole (or what ever the shape the trunk is) 50-100 mm wider than the trunk to allow the trunk to expand. Fit platfom to posts and bracing.
Don't attach anything to the tree and don't have any wood, planking etc rubbing against the tree. The tree house should come down as easily as it went up with no pain to the tree.
You could also put a roof on the platform. Make sure you put a suitable rail around it as well.
Check for planning permission and height of structures and proximity to boundaries. If this becomes problematic, don't put a roof on.
Good luck
