Throwline gun
Kings Wood Tree Care
Arborist Throw Line Deluxe Launcher Kit,3 Weights,Line,Reel,Carry Case,Save $100
Shoots Up To 150 Ft,Get Pin Point Accuracy From Ground
Is this legal in the UK!
The Americans get all the kit, crazy:laugh1:
Arborist Throw Line Deluxe Launcher Kit,3 Weights,Line,Reel,Carry Case,Save $100 | eBay
depends on its pounds per square inch if its under 12psi then its a air gun if its over 12psi then you need a firearms licence and the local firearms officer is not going to let you have it for shooting line up trees. can you see it local tree surgeon arrested for having firearm in a public place. be it air gun or firearm think not is it worth being shot to get line up tree think not
They might give you dispensation if you stipulated thatyou were going to use it to liven up your groundy though..:2gunsfiring_v1::vroam::laugh1:
Wrong.
You're getting psi mixed up with ft/lbs, which are different things entirely.
You can buy dummy launchers (for dog training) powered by .22 blanks without an FAC and this doesn't seem much different.
Probably overkill for most trees over here!
