NEW AFAG 401 climbing best practice
Arbocop
hello gang
just a little suprise for you all the new afag 401 is hot off the press now
see
http://www.hse.gov.uk/pubns/afag401.pdf
have a read this is the information hse /eho's will use to scrutinise you and there are some important changes, not least the use of the word must!!!!
time you climbers bought some new lids new standard is in and look atthose rope diamiters to mention just a few
happy reading
  • Replies 21
Cheers Kev.
I noticed the following sections [my emphasis in bold]:
14 Climbers must be aware of the different characteristics of tree species and how these affect the work to be carried out. They must also be able to assess the structure and condition of the tree to be climbed and any potential weakness caused by decay and damage.
Sounds good but the implications are wide IMO.
42 Splices should be made by someone competent to splice, eg the manufacturer. Competence should be demonstrable for each rope type.
Hmmmm I can splice but am I competent???
surely the rope diameters are the same as the old one?
from the old one
"2 1 Select ropes to provide a high margin of safety. Ropes
suitable for tree climbing must have a minimum diameter of
10 mm, although most tree-climbing ropes are at least 12 mm in
d i a m e t e r."
and
"2 2 Rope or cord used for friction hitches must be of a suitable type
and have a minimum diameter of 8 mm. Adiameter of 10 mm is
recommended for normal commercial use. Friction hitch materials
are subject to high levels of wear and should be replaced regularly,
and in any case where significant wear is found."
also, on the subject of evaluating the tree
"4 Climbers must be aware of the different characteristics of tree
species and how these affect the work to be carried out. Climbers
must also be able to recognise potential weakness caused by
d e c a y, damage or the structure of the tree."
unless i have a newer old one than you boys!!
Interesting point Tony, seems like a fair few of us on here can splice, how can it be proven that you are competent?:sneaky2:
Hello Folks
I'm sure there are many questions relating to this new guidance, unfortunately I've not read through it yet.
I will, however, ask for all & one to comment on the issue of competance as has already been mentioned. I see this as an opportunity for our industry to discuss within itself & formulate a standard.
Looking forward to hearing from yous all now!
Nod
I assume competance would be have to be assessed? So presumably by someone already competant (there's a chicken and egg issue there!) watching you splice and then taking your splice/s away from you and testing it. Then a periodic re-assessment to keep pencil-pushers like me who play at tree climbing sharp and up to date!
The picture (figure 2) appears to show someone felling a top out whilst anchored in with the side d's not the bridge.
Current best practise? Discuss.
If you have another look I'm sure you'll see he's anchored in twice.
Side D's (wire strop) and front bridge (climbing line)
:001_smile:
