New saw
Timber boy
I have heard that Husqi had a few teething problems with it when they first released it do you know if they have sorted these now ?
Yep . Sorted . Mine had as follows new carb and remapped the electricery stuff . There was also a new coil ( to aid hot starting ) and a modified starter pull mech . I think the dodgy ones were all 2012 saws . ( 2012 in the serial plate that is ) 2013 onwards should be all up to date . The thing to remember is ignition is always ON . When starting from hot don't touch the red lever . One pump of primer and de comp in and pull . ( de comp pops out just from compression so I push it in every time I pull it over even if it does not fire. This lessons the strain on the starter pull ) You must set the auto tune as per the book . Do read it ! It is the best 60cc I have used and I am 60 years old !
what do you want to use it for and what size bar do you want to use. if its just general logging then the 550xp is a cracking saw 50cc and that will do most things and its lighter than the 560. if you want a bigger saw then look at the372. i have the 576xp but the 372 is a better saw.
