I wouldn't have one unless it was as a method of training for good posture when cutting personally is plumb for the husqvarna 135 my local dealer is knocking them out for well less than £190 inc can't go wrong for a budget buy.
I just bought a husky 135, just before xmas, its not trio brake, but it is a nice little saw for logging. Just did my cs30 with it.:thumbup:
  • Replies 29
I have only recently started using the brake a bit more.
It looks pretty good to me.
I can see forestry workers warming to it more than tree surgeons who are always (often) using saws in "unconventional" ways.
Just bought a new tri 346 xp in 10 min's it will be a standard 346 xp
Did it cost more with that bit on it ? I suppose there are no more standard ones left in the shops . Here's a tip .... send it to spud and get him to poet it . He did mine and it runs a 15" bar full chiz and an 8 pin powermate . as good if not better than a 550 .......
What a waste of the best chainsaw in the last 5 years, putting that contraption on it. Husky will never fail to amaze me how crap they can be.
Sent from Hodge's eye phone using the new fancy Arbtalk Mobile App:)
Hi, I'm about to buy a new saw, and saw one with TrioBrake. I've not seen this before, but it looks like it will be too easy to activate the chain brake with your right hand. Has anyone used it?
Tried it. Didn't like it at all.
The Trio-brake is awkvard and in the way when snedding.
Would never use a trio-brake saw professionally, if I had the choice.
What it is is some lad with an engineering degree has been tasked with developing and designing something extra in the safety department .Thing ios he has probably never used a saw to earn his living . Best intentions and all that ......
I have slipped while putting the horizontal cut for a gob into a dead elm on a banking, my feet gave under me on wild garlic, it happened so quick and I ended up sliding backwards down a hill and stopped with the 25" bar sat across my neck and my right hand giving it full throttle.
Luckily I hit the chain break naturally as I have always been very strict about it with myself and workers.
The banking was nothing I would of roped off of, i dug my heels well in before hand, it was just 1 of those 1 off whoopsies that could of ended very badly!!!!!
just that quote should be a lesson to many who think that using a chain brake after almost every cut is for wusses or not always necessary ! Once you start it becomes second nature and you forget your doing it.
