As above really I'm looking for a new bigger trailer I was thinking about an ifor but now I've been offered one of these at a really good price. So any opinions or experience of them do they use leafs or are they on rubber indespencion units:confused1:
Excellent trailers, had mine for nearly 10 years, loaded and full most days with chips and logs, these are old pics (quick homemade chip box) but it's till going strong. have needed to replace an axle once and that's it. Can look out some newer pics if you want to see how they age :001_smile:
re suspension - yes independant rubber suspension
Edited by scotspine1
its difficult to go against an ifor but we've an AT36 Bateson Tilt which has done 2 years with us from new, works every day loaded up to near max and is still ok.
If its the type shown in scotspine1 pics then go for it . Iv got exactly the same and its about 8yo and virtually nothing has went wrong with it. If its a Bateson transporter with the smaller dumpy wheels stay clear of it. Iv had 2 and the chassis twisted on both because of clipping kerbs with they wheels where as the bigger skinnier ones seem to be able to handle it. Hope this helps
Scott
Cheers guys how do the rubber indespention unints hold up? Frow what I've been told I can get the same size and ramps and mesh sides but have a good saving over an ifor
Scott
I've not had that problem but my 1986 model is on its original tyres and new tyres are not available and other wheels not compatible. I wonder if there is an option to change to the later axles as the tipping gear is still good.
Just check the brakes and tyres over, it doesn't take long for them to cost more than the trailer is worth.
Sent using Arbtalk Mobile App
Will be buying a new one as I need mesh sides and ally ramps for it to so makes sense to buy new. Good point tho if your buying a second hander:thumbup1:
