Hi People,
Got a 44 with a hole in the petrol tank just over 10mm by 2/3mm on the white/right side - not the clear side.
Thinking it could probably be plastic welded and this would be preferable than some kind of sealer. But any suggestions welcome.
I not feeling great about this right now so any positive suggestions would be greatly appreciated.
Thanks
Hi People,
Thanks
sorry mate but i have never had that happen before, have you priced a new tank?:001_smile:
thats a fairly big hole! howd it happen? recon that you want a new tank really, its not like a small split that could have plastic weld used in it really
I just bought a new tank for our 44 since the back handle cracked, well it is 10 years old:001_smile: the one from the 046 fits and its got the new cap, which could be a good or bad thing depending on your love or hate for them :001_smile: personally I like them.
It cost about £50 plus vat.
As for repairing your one plastic welding might be the best bet since a lot of the epoxy resins dont like fuel, although you can get some that are for repairing fuel tanks on cars but I dont know if they are for steel tanks only :confused1:
Hi People,
Thanks
Don't know where you are in Kent, but there is a guy just outside Maidstone who does plastic welding, might do a little one off? I can weld plastic but have no equipment. A replacement tank would probably be the sensible option but I can get this blokes number if you want.
Thanks all for your suggestions - the hole isn't massive ...sort of err chain size..:blushing:
Still got the bit in it as well ...so some araldite could be the quickest/easiest/cheapest solution.
could a small bolt with rubber washers work
also have mended combi cans with rivets just to save tax payers a few squid:001_tongue:
  • 3 weeks later...
