Ganoderma species on a London plane (we've not carried out spore sampling/measurement to determine either applanatum or australe)
First 4 images from last December, last one from earlier today.
The cut wedge clearly shows the dark brown flesh.
Interesting watching the bracket develop over the space of the year.
...which sort of prods a question I have had in my mind for a while. Most of the Ganoderma I see is in private grounds or the tree gets chopped down, so I have never got to see what happens to a 'conk' a long while after you take a slice out of it. Is the last picture showing that the slice removed in the second picture has been replaced by new material or did you replace the slice and it has 'taken'. And/or do you think the removal of the slice 'killed' the conk? I know 'killed' is not the right term, but hopefully you get what I mean.
I replaced the slice of the Ganoderma in this particular instance Jules, no real reason as to why.
Often, if the mycelium/fruit body is still active, the slice (void) can just close up when it puts on another incremental pore layer as in the Perenniporia fraxinea images (1-3) & the Fomes fomentarius images (4-5)
The Fomes shots were taken 3 years apart (2008-2011)
Yellow circle shows the original slice
I did the same recently. I didn't feel like it was my place to mutilate the fruits without some attempt to make good. Even in the pursuit of knowledge it seemed wrong to leave it looking sad.
Out currently near Chichester, but found this on a site earlier on today in Surrey. My thinking is Armillaria.spp? thoughts please was on a False acacia and looks a little degraded didnt think was orang enough for Mellea.
Gymnopilus possibly what with it having a 'ring' and being a few rather than a clump. Would help in retrospect to see the gill structure. Perhaps not as devastating as the dreaded funny hungus though but an indicator that something is eating away at this tree base.
Fantastic, thanks!
Some interesting little fungs around a birch we had to lift over a footpath and some big brackets that completely encircled both these ash stems I looked at yesterday, cherrypicker removal of these me thinks!
