Hello,
The manual for my Stihl saw says that if you store a machine for longer than 3 months, you should drain and clean the fueltank.
Could anyone tell me what I should use to clean the fueltank?
Thanks
clean with a suitable solvent
i.e flush out with petrol
or just drain the tank if necessary
aspen fuel would be the best as it does not degrade and would not need flushing out
Aspen fuel is very expensive though.
not as dear as a new saw
and 2 stroke on top of fuel is also dear
and if you ever forget to put 2 stroke in saw is knacked
for someone that uses there saw every once in a while aspen would be exellent
as a lot of folk use petrol that is over 3 months sice mixed and it does brake down and does not do your saws any favours
p.s i do not use aspen but have recomended it to several bods who only use approx a gallon a year and for them i think it makes sense
and yes it is dear but so are saws and chains and sharpening ect
Was given a Stihl that hadn't been started in 13 years - still had the fuel in it! Tipped it out, flushed with half a teacup of fresh and after 12 pulls she was purring like a kitten. That's all that's needed.
  • 3 weeks later...
Briggs & Stratton make and distribute a fuel attitive which keeps petrol viable for up to two years. B&H Fresh Start Fuel Stabilizer is not pricey and one shot treats 5 litres of fuel.
The blurb states that the product will also help prevent gum from forming in the fuel system and the carburetor parts over the winter months.
I add it when I'm mixing up my two stroke fuel, it is good stuff. Most garden machinery sellers should have it.
