Veg oil in saws
Tom Richards
  • Replies 30
Well i just dont know??? the lubrication properties are good but i suspect that its too viscus, tho maybe you could add it at a lower concentration?
Ive just started producing my own biodiesel so have lots of nice filtered and de-watered waste veg laying around.
What i dont have is an old saw surplus to requirements to experiment with.
I use rapeseed oil. It's locally grown and pressed, clean and food-safe (I lick up any spills), biodegradable, I've used it in -15 with no waxing and cheap (same price as diesel...)
It's been fine without any problems when used exclusively. The only issues I've had is when I topped up a saw that was half full of stihl mineral stuff, it turned into chewing gum. So when I "convert" a saw, I run it empty, run some petrol through it and then fill with veg.
You mean less viscous; rapeseed oil from supermarket is much thinner than mineral chain oil. Turn your oiler up full!!! Flings of FAST!
spot on; same here; much cheaper and bio safe.
