  • Replies 63
bloody good behind qaud or compact tractor,plus cheaper than a tracked one too :001_smile:
exactly! i asked on here about towing with a quad. some said no...
it did it no problem:thumbup1:
My TW150 is 2.5 years old with nearly 300 hours on it. The Rotors failed the other week and the bearings were just starting to rumble. I must admit I don't always change the blades when I should and it takes some hammer so to be honest for that kind of usage with "undersized" and ungreasable bearings I don't think its too bad. In 2.5 years its cost me just over 300 quid to repair other than routine oil and filter changes and blade sharpening. I personally think the biggest downside to the machine is the vertical infeed and the poor quality jockey wheel which is now welded on.
What do you mean by that?
Does it tow ok off road ok with a quad or do you get stuck a lot?
it was fine...only problem i had was it was pee ing it down and think machine was vibrating the water up!
