Blast it! Just drove into flood and damaged engine???
TimberCutterDartmoor
Hit 12" water at 30 mph! Quiet road - didn't see it at all then thump, bow wave, all warning lights on etc etc. Engine never stalled (diesel) but lost alternator, steering etc. Everything came came back to life quickly; engine is sweet as before when revving but dull rhythmic thumping at tickover... bent con-rod ??? Lots of smoke / steam from back end of car. Manually revved engine via lever on fuel pump - intermittent mis-firing...
  • Replies 33
TCD, to bend a con rod, means that water has to get on top the piston. They won't normally turn over after that unless the water is purged from an injector. As any water had to get through the paper air filter first, it may just be that the air filter is wet and air cant get through. Try removing it and that thump may disappear along with smoke. worth a try before worrying too much?
