Does anyone know of a holster for carrying loppers?
Andy Collins
Im thinking along the lines of a secateur holster, but obviously larger. It's really because when I'm cutting a hedge (usually done by someone else!) there are always bits that are too thick to cut with the hedge cutters. I have always hung the loppers on the ladder, or laid them in the top of the hedge where I'm working, but it'd be so easy to leave them up there, or theyre never in reach when needed. Thinking a holster would make it a kittle easier...maybe.... :biggrin:
  • Replies 38
Should be fairly easy to knock something up with a couple of loops of rope to stick the handles through and attach to your belt.
Aren't you part of the make do with what you've got generation like me, rather than buy something every time.:001_smile:
(Step 1) Stare at the bits and bobs you have in the shed, then stare at the lopper.
(Step 2) Repeat this process till a solution comes to mind.
(Step 3) When the first contraption doesn't work, adapt accordingly by repeating Step 1 .:thumbup1:
Spot on. Exactly what I do. :thumbup1:
Could drill a hole in the handle and use some thin line as a strop...
