The only thing I would change about the grinder is to have a plug fitted on the end instead of crocodile clips. Then I could use it inside the workshop which is where I would really like to use it. Other than that it's been great, especially when I used it to sort a mates knackered chain out.
when i use mine in the workshop i just hook it up to a 12v battery charger:biggrin:
  • Replies 26
You can buy a fag lighter plug for pence and convert it.
Sent from my Galaxy arse using tupping talk.
Check ALL the simple things first.
I do have all these bits to fit on my dremmel . ( so you can plug it in ) .Used it one to reclaim a damaged chain . then finished it with a file . Helped a lot .
So is the general consensus that the Granberg is the best or is there a better one?
I've always been keen on one of these but my employees are useless at sharpening and I don't want to give them something that won't improve their skills.
Maybe I'll get one and ban them from it
  • 4 weeks later...
I see this 12v hand sharpner the same as using time coded vinyl and Serato Scratch :laugh1: (using your analogy)
Best of both worlds.
oldskool and analog all the way
