Got a Jenson tracked 530T that as been a great reliable machine, used most days but its getting tired and i'm wanting to replace with same but considering 540T, wise move or not? Can get 530T almost anywhere but should you stick to what you know and trust???
  • Replies 42
Depends on your work.
If you need to be in tight access situations a lot, stick with the 530.
Its remarkable where you can get a 530T with the hopper off. :001_smile:
Otherwise, go with the bigger one.
