So as the build continues. We found a section that was poorly designed so we have replaced the section and made the coupling better. Fully extended it reaches 4.8m now and can be reduced down in size if required ImageUploadedByArbtalk1428173879.048696.jpg.21e3725c80779a613857e24cfcbaf8d9.jpg
Some great Pictures recently...Hodge you know I love your neck of the woods or rather mountains..last shot is Epic....Big Butt's JB! keep us posted with the build Flatters....are you going to Pie Eater Pete's Ian?
Pie eaters Pete? Sorry a bit out of the loop since I'm looking after the wife at the moment. What is it?
Reccy climb May 22nd near Bolton. ..there's a thread...I'll send you details on Facebook...brilliant if you and Adam could get there..if not,see you at the show probably. What body are you looking to put on the trailer bed?
It's a micro forestry trailer we've just took the blaster pipes off at the moment. Just making it easier for the skid steer to load or extract from.
[ATTACH]179710[/ATTACH][ATTACH]179711[/ATTACH][ATTACH]179712[/ATTACH][ATTACH]179713[/ATTACH][ATTACH]179714[/ATTACH][ATTACH]179715[/ATTACH][ATTACH]179716[/ATTACH]
Finished this off by lunch today. Last lump was 4ish tonne. RB load of logs too. Stump 6ft across.
Which company do you use for the Hiab?
Thanks.
Update for you Paul: sorted a bit of subframe maintenance out as there was some play on the adjustable drawbar. The trailer now goes from 15ft 10" and expands to 18ft the crane can lift 330kgs close and 160kgs at full reach. ImageUploadedByArbtalk1428347599.130353.jpg.ed009008836b799d166e9e5e8512f859.jpg
