Rigging down a lighting struck Pine tree
T.C
[ame=http://www.youtube.com/watch?v=Mr_cLzyqhfI&feature=player_embedded]Dismantling Pine Tree - YouTube[/ame]
Due to lighting damage and its position to the road this large pine was condemned and taken down.
I can be watched in HD if you so choose, comments as always welcome!
TC
Good job,nice work.:thumbup1:
Just wondering who you work for?Just being nosey as im from Dumfries.
Also why did you change from SJ to HC?
I am self-employed, based in North Yorkshire. Did the job for a friend who lives up there. The job took a very leisurely 2 days over the weekend. The reason for the switch from SJ to HC was because on the second day I used a Pantin to ascend right to the top and I prefer using the HC with the Pantin.
Best
TC
When you are ropping the trunk down you should use a chogging cut and then push it off or let it slide off on its own. Its alot faster than doing a felling cut and then using a wedge and hammer. Your making more work for yourself than needed also because its tough to push wood which has a hinge with the weight of the wood included. I saw you struggling abit on this so I thought I would at least mention it.
