Hi peeps i am not opening the can of whats better a hilux or a landy.
I need a tipping 4x4 as my circumstances have changed a bit, i currently run an ldv crew cab, so this is a major down size :thumbdown:
My question is- Is what is bigger a land rover 110 tipper or a hilux tipper?I know a 130 beets them all but i really dont have the £ for a 130 as i am buying my first place with the missis at the moment.
Thanks in advanced :thumbup:
  • Replies 23
The chasis length behind the cab is bigger on a hilux but like furguson forestry said you can fit what ever size body you want. Let's be honest tho you would be mug to buy a hilux over a landrover
110 tipper will carry more weight than a hilux, especially if you go for a HD version at 3500kg GVW - chances are it will then carry more weight than the LDV can too.
I work with a guy who used to run a hilux tipper and upgraded to a 110 HD tipper and he says the difference in how it handles the weight compared to the hilux is huge.
single cab hilux gross weight 2500kg with load. so once you have body on will be lucky to carry half a tonne. I think unfortunately the defender is your only option. The hilux is vastly better made but carries less than half the weight.
