Just was wondered what extraordinary ways people have of removing stumps.
I've got to get 4 small coni stumps out and they're on a walled bed which has shrubs and the customer doesn't want a grinder in there. Ye I can dig them out but what about using a farm jack or 4x4 to pull them out or a winch?
  • Replies 24
How high?
We Tirfor a lot of stumps out, but you need a lever arm, or you're screwed.
Otherwise you can't get round the digging bit.
(let's not have the usual stuff about fores and explosives please lads!).
Done afew jobs this year as above , what I do and it works for me is dig around them then use the blower to clear the soil cut what you see(soil saw) dig some more and rock the stump , this work well for me , if you leave the stump about 3 to 4 foot above ground BUT and there is always a but , the tap root it there belive me . I will be buying a tirfor year.Taking out all sizes up to 16/20".
Hope this help's you.
? on this note is willow roots easy to grind out , job on Monday and Tuesday 5ft wide.
Chainsaw them into a swedish candle and then use a splitting wedge to remove them root at a time.
Quite like the idea of setting fire to the blighters
Willow should be pretty easy. The worst grinding job I've done was a 6' Elm. Took me all day with a blunt old vermeer I think...... Dead cherry is a swine too.
