  • Replies 471
For bigger bits I use a bigger rope.
In all seriousness, it isn't a basic kit but I have 60m polydine 16mm. Impact block, a few x rings, a couple of swing cheek pulleys, various loop slings and deadeyes for pulleys etc and a Stein fixed bollard. Plus a load of steel crabs to connect bits together.
Anybody here using x rings and could they be used in place of a standard block??
I nearly use x rings all the time I can't remember the last time I used a pulley in a rigging scenario i use pulleys for re directs on the ground when pulling trees over or maybe snatching very big wood on a pole I will use a big impact block
Sent from my SM-G930F using Arbtalk mobile app
What Set up do you have with them? Think it's only treekit that have them spliced up.
Also like the look of the shizll sling with a ring
I just spliced the xrings myself.
Pretty easy to splice onto Tenex and if you follow the Instructions from the manufacturer then it will be bomber.
Have a few rings would rather use pulleys personally so you can balance big limbs and crank them around on the lowering device or pretension to avoid shock loading,rarely use the rings, they run nice and smooth but seem a throw back to topping strop days.
Ya and I think choosing ur own combinations of rings and Lengths of tails or if u want em on a Whoopi sling to suite ur style of climbing and work u will be using them for is best I do mainly big take downs so I have em made up to suite that work
