Next doer-upper recommendation please?
Adamam
So far I've made-functional a Dolmar 100 and a Stihl 028, I'd like to try a Husqvarna next. Is there a vague equivalent to the 028?
Something around the 45-50cc mark that I can still get parts for and that I can score for £150 or less on Evilbay?
Ta!
Edited by Adamam
I recognise the question you're asking, but maybe an alternative perspective. You're looking for another saw in the same size bracket. Once done, that will give you three equivalent saws. Do you have anything in mind for them, or do you use saws at all? (not meant in any way negatively, just interested in whether the entertainment is in the fixing or the use, or both).
If you're actually using saws, one thing to consider might be to look out for a bigger one to extend the range of what you can do. If so, I'd keep an eye out for a siezed 044 which should turn up in the right price bracket (mine was £98!). You might then need to get someone to do a pressure check on it before you start dismantling (or set yourself up with a pressure testing kit) so you know what if anything leaks, and then give it a go. It's a good, solid model, pretty handy for up to a 20" bar and the parts are readily available.
Just a thought.
Alec
