Hi guys looking for a little help, advice etc.
Have just brought a little Rayco 13 stump grinder from Daniel@Chippertech,
used it a couple of times now and the teeth are getting a tad worn.
Wanted to find out from you guys where you all get your grinder finger teeth from?
Got told by a mate it doesn't matter how expensive they are they are wear the same.
So, I suppose the real question is where can I get cheap grinder finger teeth from and how much do you pay???
Cheers Guys, Horatio
  • Replies 24
get a bench grinder and a green wheel and sharpen you own, i did for a good few years until i went onto multitip.
if you want new cheapest pace is saturn machine knives.
And a dust mask and eye protection...
Where are you based, I have a guy who sharpens them for 50p each. Only worth it if your local though.
I am in Diss on the Norfolk Suffolk border.
Thanks a lot for your help.
Sods law I am gonna be miles apon miles away!
Are you happy with them, what grinder are you using them on. We have ours fitted to a Predator 28
I find we use either one or some times two of the leader teeth and the sides are virtually untouched, seems a bit of a waste.
Might be better and stronger if the two leader teeth were made as one to give them more strength.
Saturn machine knives for finger teeth get my vote.
i have a rayco rg13mkII, i fitted the multi tip cutting system, it was about 400 quid but worth every penny, it out performs all the other teeth including green teeth. it feels like a bigger machine. yesterday i did a 10" connie stump in under 15 mins including unloading and tidying up.
Find multitip great, v cost affective and sooo easy to change, no swinging on a breaker bar trying to undo the bolts.:thumbup1:
