Ms 200t rewind spring - Rewinding
Dog Tag
not done a 200 but on honda engines you remove pull cord handle pulll rope through hole into casing , wind rope around pulley and theres a groove that you can hold rope into ,wind until the tension is ok then put rope back through and fit handle im sure spud will give a proper answer for you
Push the spring in to the recoil cover where there is the molded channel to receive it and then keep working the spring back in to the spring cavity until it has gone back completely.
This is the only way I know.
I also wear safety specs just in case.
The recoil pulley should just push in to place with a bit of rotating.
As Spud says for the spring.
When you wind the cord on make sure that when the cord is fully out, it is stopped by the knot not allowing the pulley to turn further.
As opposed to the spring being coil bound and stopping further movement of the pulley.
The latter wil result in spring breakage.
That is one very good tip that probably many overlook:thumbup:
Spuds way sounds pretty good. I've done it before using strong fingers and patience. Think i did it once coiling the spring from the centre using a pen, but I'd definitely try Spuds method.
Yep, I broke several springs years ago until I sussed this.
As regards winding the spring, I do have a proper winding tool, but seldom use it. I usually wind the spring in my fingers, away from the housing. I pull it tighter and tighter until its outside diameter is just less than the housing and then clamp it with some snipe nose vice grips. Then insert it in the housing and release the grips.
My fingers then slowly uncramp over the next hour or two.:lol:
