climbing saw
drosa2004
  • Replies 30
Most of the guys on here will run a 12" or 14" on a Stihl MS200T, a 16" wouldn't be great and would bog more on large cuts and would be less manageable.
The MS200T has good pulling power, some top handles are less powerful and would only pull a 12".
What I am saying is that you need to match the saw to the bar and the intended use of the saw - a saw may take a larger bar but doesn't mean it will be nice to use!
What saw are you using?
I use a ms200t with a 14" bar for dismantling and pruning, but think i may try a 12" bar for pruning....
14" is plenty! i cut through allsorts of diameter wood when blocking down, till i get a bigger saw passed up!
Leave the 16" for the americans
Stihl MS200T
Stihl MS200T
Then the 12" will give you a saw that will maintain a high cut speed on large cuts to 10" or the 14" will give you the abillity to take on larger limbs but you may see a drop of chain speed on larger cuts. Both will work well on the saw.
A larger bar IMO would make the saw unbalanced but I am not a climber, just a tech.
