  • Replies 40
if your removing the rocks or should i say the wife is.why not get it ground out or even a percentage of it less back breaking work.
He's says there is no access for a machine mate
Would it be possible to burn it out? :001_smile:
Felix its interesting you say that , ive got two large dead beech stumps to remove and was thinking of doing just that but not sure of its effectiveness . I'm a bit of a pyro-maniac so it fits into my remit . Seriously though is this a viable course of action :001_smile:
As long as you aren't going to burn down anything nearby :biggrin:
I had a eucalyptus tree cut down and now im trying to remove the stump but the blackspur axe i got is a load of rubbish so im hoping someone could recommend me a axe as i have heard that gransfors bruks are the best but it's to expensive for what i want it for.
If you've got the patience, don't mind the work (which seems to be the case!) and there are stone/rock issues get yourself a mattock and keep the smaller cutting blade sharp. Use the wide hacking blade for stones and soil, the cutting blade for the roots. Remember that the further from the trunk you cut the roots the smaller they'll be.
But a 30" tree is still a fair stump to dig out by hand: any chance of getting a winch onto it as well? If you can cut a big root a couple of feet from the trunk the stub could be your attachment point to get a bit of leverage. Every little helps...
Where are you - nowhere near me I hope as I wouldn't want to get involved! :001_tt2:
