Ive had 265 75 r16. Cooper stt's not bfg's
dont know if that helps - but some of the numbers match :)
Edited by Dean O
additional info
I have 235/85.16's on my 90, the drivers side wheel on full lock catch's the radious arm on full lock.. left hand down. and i'm on BFG A/T'S, other than that no problems.......
If the tyres fit the rims they will fit. However 235/75/16 will look a little lost in the wheel arches of a defender.
If 235/85/16s are rubbing on your radius arms at full lock, you need to adjust your lock stops. I have 265/85/16 on mine (I think) and they were rubbing but adjusted the lock stops and they are fine now. I though I was going to have to fit wheel spacers. They other option is wheels with a larger offset.
