I know very little about roadbuilding but I have seen/heard of tyre bales being used in the lower courses in boggy areas to reduce the amount of stone needed - you can get the tyre bales for free
  • Replies 26
Is it worth looking at what the peat extraction industry use? Lot of twin wheel conversions, but also half track and full track conversions of agricultural tractors: Turf hopper machine...Ford TW20 tractor | Flickr - Photo Sharing!
Images published in Technical Report TR08/CNV00028
Images published in Technical Report TR08/CNV00072, might be something available somewhere second hand?
Also they have specially built stuff
Peat Machinery - Mini excavator buckets, excavator rake, excavator quick hitch, pole grab, backhoe and loader buckets, skid steer buckets - Peat Trailer
Images published in Technical Report TR08/CNV00020
Images published in Technical Report TR08/CNV00051
sometimes adapted from land drainage equipment, which is another industry that has similar problems.
Only if there is a generous grant?
Otherwise I fink a 2nd Dozer/crawler ud be cheaper?
You could be eligible for upto 50% on the new parts but there will be no grant available on the 2nd hand dozer so I would not discount it straight away until you do the sums.
Have you considered that rubber matting used at festivals and the metal version like at the APF to gain acccess. Then use that area at the woodland for winching and extraction.
No idea how large the wood is so difficult to see.
